주요 콘텐츠로 건너뛰기
Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement
필요한 것
  1. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
  2. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the battery out of the battery slot.
  3. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Remove the two 6mm PH1 screws from the bottom of the laptop.
  4. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 4 단계, 이미지 1개 중 1개
    • Use the spudger, push the two tabs, located in the battery slot, through their slots to release the keyboard.
    • Do this with the computer slightly open for ease.
  5. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 5 단계, 이미지 2개 중 2개
    • Open the laptop.
    • Start top of the keyboard and use the opening tool to pop the remaining tabs around the keyboard loose.
    • The keyboard can be flipped onto its face once removed.
  6. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 6 단계, 이미지 1개 중 1개
    • Use the spudger and slide the grey tabs on either side of the keyboard wires away from the white plastic.
  7. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the keyboard by pulling the blue tape on the wire strip.
  8. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement, Hard Disk Drive (HDD): 8 단계, 이미지 1개 중 1개
    • Remove the five 6mm PH1 screws beneath the keyboard.
  9. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 9 단계, 이미지 2개 중 2개
    • Use the spudger to pop the gray tab up and away from the far left wire strip.
    • Disconnect the wire strip by pulling the blue tab loose.
  10. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 10 단계, 이미지 2개 중 1개 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 10 단계, 이미지 2개 중 2개
    • Use the spudger to pop the white tab up away from the wire strip located at the top left corner of the mouse pad.
    • Disconnect the wire strip by pulling the blue tab.
  11. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 11 단계, 이미지 1개 중 1개
    • Close the laptop.
    • Remove the remaining 18 6mm PH1 screws from the bottom cover of the laptop.
  12. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 12 단계, 이미지 3개 중 1개 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 12 단계, 이미지 3개 중 2개 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 12 단계, 이미지 3개 중 3개
    • Use the opening tool to separate the back of the laptop from the inside cover.
    • Open the computer and remove the inside cover.
  13. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 13 단계, 이미지 3개 중 1개 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 13 단계, 이미지 3개 중 2개 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 13 단계, 이미지 3개 중 3개
    • Lift the HDD out of the base and use the opening tool to disconnect the HDD from the motherboard wire.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Lakbira Sheffield
회원 가입일: 01/29/18
718 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 879
