주요 콘텐츠로 건너뛰기
Acer Aspire V5-571P-6815 Charging Port Replacement
필요한 것
  1. Acer Aspire V5-571P-6815 Charging Port Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer and unplug all power.
  2. Acer Aspire V5-571P-6815 Charging Port Replacement: 2 단계, 이미지 1/2 Acer Aspire V5-571P-6815 Charging Port Replacement: 2 단계, 이미지 2/2
    • Slide the locking latch to the right and hold while pulling the battery out with your other hand.
  3. Acer Aspire V5-571P-6815 Charging Port Replacement, Keyboard: 3 단계, 이미지 1/1
    • Remove the two 7mm Phillips #00 screws from the bottom of the laptop.
  4. Acer Aspire V5-571P-6815 Charging Port Replacement: 4 단계, 이미지 1/3 Acer Aspire V5-571P-6815 Charging Port Replacement: 4 단계, 이미지 2/3 Acer Aspire V5-571P-6815 Charging Port Replacement: 4 단계, 이미지 3/3
    • Insert a plastic opening tool underneath the keyboard and pry upwards.
    • Slide the plastic opening tool around the perimeter to free the keyboard.
    • Flip the keyboard over and onto the palm rest.
  5. Acer Aspire V5-571P-6815 Charging Port Replacement: 5 단계, 이미지 1/3 Acer Aspire V5-571P-6815 Charging Port Replacement: 5 단계, 이미지 2/3 Acer Aspire V5-571P-6815 Charging Port Replacement: 5 단계, 이미지 3/3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
    • Remove the keyboard from the laptop.
  6. Acer Aspire V5-571P-6815 Charging Port Replacement, Charging Port: 6 단계, 이미지 1/1
    • Remove the six 6mm Phillips #0 screws from underneath the keyboard.
  7. Acer Aspire V5-571P-6815 Charging Port Replacement: 7 단계, 이미지 1/1
    • Remove the sixteen 6mm Phillips #0 screws from the bottom cover.
  8. Acer Aspire V5-571P-6815 Charging Port Replacement: 8 단계, 이미지 1/3 Acer Aspire V5-571P-6815 Charging Port Replacement: 8 단계, 이미지 2/3 Acer Aspire V5-571P-6815 Charging Port Replacement: 8 단계, 이미지 3/3
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
    • Pull the ribbon cable from the socket.
  9. Acer Aspire V5-571P-6815 Charging Port Replacement: 9 단계, 이미지 1/2 Acer Aspire V5-571P-6815 Charging Port Replacement: 9 단계, 이미지 2/2
  10. Acer Aspire V5-571P-6815 Charging Port Replacement: 10 단계, 이미지 1/3 Acer Aspire V5-571P-6815 Charging Port Replacement: 10 단계, 이미지 2/3 Acer Aspire V5-571P-6815 Charging Port Replacement: 10 단계, 이미지 3/3
    • Use a plastic opening tool to pry up the palm rest from the laptop body.
    • Remove the palm rest from the laptop.
  11. Acer Aspire V5-571P-6815 Charging Port Replacement: 11 단계, 이미지 1/2 Acer Aspire V5-571P-6815 Charging Port Replacement: 11 단계, 이미지 2/2
    • Disconnect the charging port cable from the motherboard.
    • You might have to remove some electrical tape that is in the way.
  12. Acer Aspire V5-571P-6815 Charging Port Replacement: 12 단계, 이미지 1/3 Acer Aspire V5-571P-6815 Charging Port Replacement: 12 단계, 이미지 2/3 Acer Aspire V5-571P-6815 Charging Port Replacement: 12 단계, 이미지 3/3
    • Lift the charging port up and out of the laptop.
결론
Follow the steps in reverse with a new cable.
다른 한 분이 해당 안내서를 완성하였습니다.
Gordon Tran
회원 가입일: 04/12/18
225 평판
안내서 1개 작성함
UW Tacoma, Team S1-G4, Liner Spring 2018 UW Tacoma, Team S1-G4, Liner Spring 2018 회원
UWT-LINER-S18S1G4
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 25
전체 시간: 5,589
