주요 콘텐츠로 건너뛰기
Acer Aspire V5-571P-6815 Keyboard Replacement
필요한 것
  1. Acer Aspire V5-571P-6815 Keyboard  Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Remove the two 7mm Phillips #00 screws from the bottom of the laptop.
  2. Acer Aspire V5-571P-6815 Keyboard  Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire V5-571P-6815 Keyboard  Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire V5-571P-6815 Keyboard  Replacement: 2 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool underneath the keyboard and pry upwards.
    • Slide the plastic opening tool around the perimeter to free the keyboard.
    • Flip the keyboard over and onto the palm rest.
  3. Acer Aspire V5-571P-6815 Keyboard  Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire V5-571P-6815 Keyboard  Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire V5-571P-6815 Keyboard  Replacement: 3 단계, 이미지 3개 중 3개
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
    • Remove the keyboard from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jmarqu2
회원 가입일: 04/12/18
133 평판
안내서 1개를 작성함
UW Tacoma, Team S1-G4, Liner Spring 2018 UW Tacoma, Team S1-G4, Liner Spring 2018 회원
UWT-LINER-S18S1G4
5 회원들
안내서 8개를 작성함
2가이드 댓글
This guide is wrong. All keyboard sold online come without the frame and replacing the keyboard is actually a very tedious process as it’s attached with melt plastic.
Sergey Ratakhin - 답글
Thank you! All this guide shows is how to take out and put in the exact same keyboard, which doesn't seem to be available anywhere. I've been looking for an exact replacement and haven't been able to find one. The original keyboard has the frame with the power button. NONE of the replacement options has ANYTHING with the power button.
Raul - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 31
전체 시간: 3,604
