주요 콘텐츠로 건너뛰기
Acer Aspire V5-572 - Battery Reset Pinhole
필요한 것
  1. Acer Aspire V5-572 - Battery Reset Pinhole, Acer Aspire V5-572 - Battery Reset Pinhole: 1 단계, 이미지 3개 중 1개 Acer Aspire V5-572 - Battery Reset Pinhole, Acer Aspire V5-572 - Battery Reset Pinhole: 1 단계, 이미지 3개 중 2개 Acer Aspire V5-572 - Battery Reset Pinhole, Acer Aspire V5-572 - Battery Reset Pinhole: 1 단계, 이미지 3개 중 3개
    • At the bottom side of the laptop, you will find a small pinhole.
    • Insert a paperclip into the hole and press for four seconds to reset the computer.
결론
다른 34명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,093 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 40개
Yep-it worked exactly as suggested. Sharp end of a small safety pin and bobs your uncle.
Thanks again. Was worried that it could be something worse.
Russ
dabblers2 - 답글
Its not working on my laptop Acer aspire S3.. I press it in 4 second but its not gonna work.
What can I do to fix it?
dongyul54 - 답글
For those whose laptops are not working for pressing it for 4 seconds ..please follow the steps that i had explained below because i chat with the acer care and they told me these steps which helps me to fixed my acer aspire 7
Step 1 :- remove charger from the laptop
Step 2:- press the power button for 30 seconds
Step 3:- press the pin hole button for 25 seconds with the help of a paper clip or sim ejector tool .
Step 4 :- plug in the charger in the laptop and let it charge for 1 hour after 1 hour power on the laptop .....and boom your laptop will start working .....this trick will 100% work as this fixed my laptop
Atul -
Ok, it works perfectly..., thank you to your suggest.
My Acer Aspire ES1-512-C08J, did not accept anythink from keyboard to input password at start of windows 10, but in Bios setup did it works.
No solutions to change keyboard, or reset bios to default configuration, but only when i pushed in the pinhole reset switch battery on back laptop, while laptop was on, and it immediatly drops down switch off, and when i restart laptop from normal push button power on, all works another time ok.....
Sorry for my bad english...
Vito Perrino - 답글
Should I perform these steps with the laptop turned on or turned off?
Ridhwaan Hassim - 답글
댓글 쓰기
조회 통계:
지난 24시간: 25
지난 7일: 169
지난 30일: 829
전체 시간: 208,009
