주요 콘텐츠로 건너뛰기
Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement
필요한 것
동영상 개요
  1. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 2 단계, 이미지 1개 중 1개
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 3 단계, 이미지 3개 중 3개
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Cooling / Fan System: 5 단계, 이미지 2개 중 1개 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Cooling / Fan System: 5 단계, 이미지 2개 중 2개
    • Disconnect the Fan cable.
    • Remove the three screws from the CPU cooler and one from the Fan module.
    • When you change the Cooling system, you must clean the processor from old thermal compound and put new.
  6. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 6 단계, 이미지 3개 중 1개 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 6 단계, 이미지 3개 중 2개 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 6 단계, 이미지 3개 중 3개
    • Use a lint-free cloth to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Use again cloth with isopropyl alcohol to clean the Thermal surface.
  7. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 7 단계, 이미지 3개 중 1개 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 7 단계, 이미지 3개 중 2개 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 3x Phillips screws and open the Fan case.
    • Use a soft brush and clean the Fan and the Cooler.
  8. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 8 단계, 이미지 3개 중 1개 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 8 단계, 이미지 3개 중 2개 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 8 단계, 이미지 3개 중 3개
    • Use the same technic to clean the surface of the processor from the old thermal compound
    • Be carefully,if you don't want to break the CPU.
    • Dispense a small amount of thermal compound and gently smear it over the entire processor surface.
  9. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 9 단계, 이미지 2개 중 2개
    • Careful install the Cooling system with even pressure from all sides, and the bead that you placed on the surface will spread over the entire contact surface.
결론
작성자
3다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,093 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 3,289
