주요 콘텐츠로 건너뛰기
Acer Aspire V5-572, V5-572G HDD Replacement
필요한 것
동영상 개요
  1. Acer Aspire V5-572, V5-572G HDD Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G HDD Replacement: 2 단계, 이미지 1개 중 1개
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G HDD Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire V5-572, V5-572G HDD Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire V5-572, V5-572G HDD Replacement: 3 단계, 이미지 3개 중 3개
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G HDD Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G HDD Replacement, HDD: 5 단계, 이미지 3개 중 1개 Acer Aspire V5-572, V5-572G HDD Replacement, HDD: 5 단계, 이미지 3개 중 2개 Acer Aspire V5-572, V5-572G HDD Replacement, HDD: 5 단계, 이미지 3개 중 3개
    • Disconnect the SATA Cable from the Mother Board.
    • Take out the HDD and remove the SATA cable from it.
    • Now you can change / upgrade your HDD.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,093 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 7개
Thank you very much for the tutorial, it was a 12 minute job ☺️And extremely pleased with the new ssd its incredible
Best Regards
Luckystyx - 답글
Thank you so much for the extremely easy tutorial and it definitely only took 2 minutes longer (12 minutes)
Your site is invaluable, Keep up the great work and all that you do,
5 star rating for you guys..
Kindest Regards
@Styx
Luckystyx - 답글
So the original hdd came in with the win 7 and it was later upgraded to win 10 for free. If i change it to ssd would i be able to get on it my original copy of win 7 and will it upgrade to win 10?
ashmir - 답글
ashmir, you just clone your HDD with a free software such as Macrium Reflect and don’t need to worry about installing everything from zero!!!
Miguel Rodríguez - 답글
Thank you for the tutorial.
But need a clarification. If i have a faulty hard disc it starts up but it freezes after 20 minutes.
Is it still possible to clone it.
Also if i change the hard drive do I need to install any software or the bios all over again.
Your inputs will be appreciated.
olatunji.jimoh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 98
전체 시간: 18,655
