주요 콘텐츠로 건너뛰기
Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement
필요한 것
동영상 개요
  1. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: 2 단계, 이미지 1개 중 1개
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: 3 단계, 이미지 3개 중 3개
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Remove the single Phillips 0 screw securing the battery.
  6. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the battery
  7. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Loudspeakers and Microphone: 7 단계, 이미지 3개 중 1개 Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Loudspeakers and Microphone: 7 단계, 이미지 3개 중 2개 Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Loudspeakers and Microphone: 7 단계, 이미지 3개 중 3개
    • Disconnect the Loudspeakers cable.
    • There are two modules with loudspeakers, connected with one wire.
    • Unscrew the screws and remove the Loudspeaker modules together with the cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,093 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 23
전체 시간: 2,506
