주요 콘텐츠로 건너뛰기
Acer Aspire V5-572, V5-572G Mainboard Replacement
필요한 것
동영상 개요
  1. Acer Aspire V5-572, V5-572G Mainboard Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Mainboard Replacement: 2 단계, 이미지 1개 중 1개
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Mainboard Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire V5-572, V5-572G Mainboard Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire V5-572, V5-572G Mainboard Replacement: 3 단계, 이미지 3개 중 3개
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Mainboard Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Mainboard Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Remove the single Phillips 0 screw securing the battery.
  6. Acer Aspire V5-572, V5-572G Mainboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the battery
  7. Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: 7 단계, 이미지 3개 중 1개 Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: 7 단계, 이미지 3개 중 2개 Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: 7 단계, 이미지 3개 중 3개
    • Disconnect the SATA Cable from the Mother Board.
    • Take out the HDD and remove the SATA cable from it.
    • Now you can change / upgrade your HDD.
  8. Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: 8 단계, 이미지 3개 중 1개 Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: 8 단계, 이미지 3개 중 2개 Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: 8 단계, 이미지 3개 중 3개
    • Remove 1x screw and disconnect the two antenna coaxial cables.
    • Remove the Wi-Fi card from the slot.
  9. Acer Aspire V5-572, V5-572G Mainboard Replacement, Cooling / Fan System: 9 단계, 이미지 2개 중 1개 Acer Aspire V5-572, V5-572G Mainboard Replacement, Cooling / Fan System: 9 단계, 이미지 2개 중 2개
    • Disconnect the Fan cable.
    • Remove the three screws from the CPU cooler and one from the Fan module.
    • When you change the Cooling system, you must clean the processor from old thermal compound and put new.
  10. Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: 10 단계, 이미지 3개 중 1개 Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: 10 단계, 이미지 3개 중 2개 Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: 10 단계, 이미지 3개 중 3개
    • Disconnect one by one:
    • LCD Display flex cable
    • DC Jack cable
    • USB Board flex cable
    • Touch pad flex cable
    • Keyboard flex cable
  11. Acer Aspire V5-572, V5-572G Mainboard Replacement: 11 단계, 이미지 3개 중 1개 Acer Aspire V5-572, V5-572G Mainboard Replacement: 11 단계, 이미지 3개 중 2개 Acer Aspire V5-572, V5-572G Mainboard Replacement: 11 단계, 이미지 3개 중 3개
    • Disconnect the Loudspeakers and the Microphone cables.
    • Remove 6x Phillips screws, 3x from the Main board and 3x from the hinge.
    • Open a little the laptop to open the hinge.
    • By hand, open the hinge to the end.
  12. Acer Aspire V5-572, V5-572G Mainboard Replacement: 12 단계, 이미지 3개 중 1개 Acer Aspire V5-572, V5-572G Mainboard Replacement: 12 단계, 이미지 3개 중 2개 Acer Aspire V5-572, V5-572G Mainboard Replacement: 12 단계, 이미지 3개 중 3개
    • Carefully remove the the Main board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,093 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 한 개
where did you find your motherboard replacement? Or whats model is it? I need to replace my mb but cant find any online for sale.
Ruby - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 15
전체 시간: 4,783
