주요 콘텐츠로 건너뛰기
Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade
필요한 것
동영상 개요
  1. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: 2 단계, 이미지 1개 중 1개
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: 3 단계, 이미지 3개 중 1개 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: 3 단계, 이미지 3개 중 2개 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: 3 단계, 이미지 3개 중 3개
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: 4 단계, 이미지 1개 중 1개
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): 5 단계, 이미지 3개 중 1개 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): 5 단계, 이미지 3개 중 2개 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): 5 단계, 이미지 3개 중 3개
    • This model have 1x Memory Slot.
    • You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,093 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 한 개
Hi,
While adding an extra RAM to the module in Aspire V5-472, I forgot to disconnnect the battery first.
I first tried 4 GB RAM compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. When that didn't work, I checked again.
Next time I disconnected the battery, and repeated the process with 2 GB RAM, compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. The RAM was still not discovered. None of the RAMs were detected.
Hope I haven't fried the RAM Module itself.
Please help.
Indi Shukla - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 15
지난 30일: 106
전체 시간: 23,692
