주요 콘텐츠로 건너뛰기
Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement
필요한 것
동영상 개요
  1. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: 2 단계, 이미지 1/1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: 3 단계, 이미지 1/3 Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: 3 단계, 이미지 2/3 Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: 3 단계, 이미지 3/3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: 4 단계, 이미지 1/1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement, Wi-Fi half mini PCIe card: 5 단계, 이미지 1/3 Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement, Wi-Fi half mini PCIe card: 5 단계, 이미지 2/3 Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement, Wi-Fi half mini PCIe card: 5 단계, 이미지 3/3
    • Remove 1x screw and disconnect the two antenna coaxial cables.
    • Remove the Wi-Fi card from the slot.
결론
ZFix
회원 가입일: 12/09/13
192,056 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,525개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 34
전체 시간: 4,582
