소개
Acer Aspire V5-591G-75KE is manufactured with a 6-cell Lithium Ion (Li-Ion) 5040 mAh laptop battery. Batteries in laptops are very specific in their shape and capacity, so make sure you obtain a suitable replacement for the Acer Aspire V5-591G-75KE.
필요한 것
Close down the display and flip the device upside down.
Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
The laptop battery is the black rectangular item at the top.
The battery connects to the motherboard via a multi-colored 8-pin connector.
Using a pair of blunt tweezers, push the white tabs on the sides 8-pin connector to disconnect the battery from the motherboard.
다른 2명이 해당 안내서를 완성하였습니다.
