주요 콘텐츠로 건너뛰기
Acer Aspire V5-591G-75KE Memory Modules Replacement
필요한 것
  1. Acer Aspire V5-591G-75KE Memory Modules Replacement, Acer Aspire V5-591G-75KE Disassembly: 1 단계, 이미지 3개 중 1개 Acer Aspire V5-591G-75KE Memory Modules Replacement, Acer Aspire V5-591G-75KE Disassembly: 1 단계, 이미지 3개 중 2개 Acer Aspire V5-591G-75KE Memory Modules Replacement, Acer Aspire V5-591G-75KE Disassembly: 1 단계, 이미지 3개 중 3개
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Memory Modules Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire V5-591G-75KE Memory Modules Replacement: 2 단계, 이미지 2개 중 2개
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Memory Modules Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire V5-591G-75KE Memory Modules Replacement: 3 단계, 이미지 2개 중 2개
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Memory Modules Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire V5-591G-75KE Memory Modules Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire V5-591G-75KE Memory Modules Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Memory Modules Replacement, Memory Modules: 5 단계, 이미지 3개 중 1개 Acer Aspire V5-591G-75KE Memory Modules Replacement, Memory Modules: 5 단계, 이미지 3개 중 2개 Acer Aspire V5-591G-75KE Memory Modules Replacement, Memory Modules: 5 단계, 이미지 3개 중 3개
    • Locate the memory modules at the bottom right quadrant of the motherboard. The two memory modules are slightly stacked on top of each other.
    • Using both hands, pull the clasps away simultaneously in order to release the memory modules.
    • Once the clasps have been released, each memory module will spring up.
  6. Acer Aspire V5-591G-75KE Memory Modules Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire V5-591G-75KE Memory Modules Replacement: 6 단계, 이미지 2개 중 2개
    • To remove the top memory module, lift the module slightly up and pull away.
    • Repeat the previous step to remove the bottom memory module.
    • Take note of the pins on the bottom of each memory module and make sure they line up with the slots when re-installing the memory modules. Once aligned and inserted, simply push the memory module down to lock it in place.
결론
작성자
2다른 기여자 명과 함께
Reina Godeck
회원 가입일: 10/16/17
741 평판
안내서 5개를 작성함
UW Tacoma, Team S3-G5, Liner Fall 2017 UW Tacoma, Team S3-G5, Liner Fall 2017 회원
UWT-LINER-F17S3G5
4 회원들
안내서 18개를 작성함
댓글 한 개
Great job on the guide! looks very professional!
Aiden - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 17
전체 시간: 522
