주요 콘텐츠로 건너뛰기
Acer Aspire a515-46 SSD Replacement
필요한 것
  1. Acer Aspire a515-46 SSD Replacement, Turn off: 1 단계, 이미지 1개 중 1개
    • If laptop is not already off, hold power button for 5 seconds until screen shuts off.
    • If needed, backup any files to a USB or an external hard drive before turning off and replacing SSD.
  2. Acer Aspire a515-46 SSD Replacement, Remove Back Panel 1 of 3: 2 단계, 이미지 1개 중 1개
    • Flip the laptop over and locate the screws on the back panel.
  3. Acer Aspire a515-46 SSD Replacement, Remove Back Panel 2 of 3: 3 단계, 이미지 3개 중 1개 Acer Aspire a515-46 SSD Replacement, Remove Back Panel 2 of 3: 3 단계, 이미지 3개 중 2개 Acer Aspire a515-46 SSD Replacement, Remove Back Panel 2 of 3: 3 단계, 이미지 3개 중 3개
    • Using a Philips head screwdriver, remove all of the screws on the back panel.
  4. Acer Aspire a515-46 SSD Replacement, Remove Back Panel 3 of 3: 4 단계, 이미지 3개 중 1개 Acer Aspire a515-46 SSD Replacement, Remove Back Panel 3 of 3: 4 단계, 이미지 3개 중 2개 Acer Aspire a515-46 SSD Replacement, Remove Back Panel 3 of 3: 4 단계, 이미지 3개 중 3개
    • Use a small screwdriver or prybar to pry the back panel away from the laptop.
  5. Acer Aspire a515-46 SSD Replacement, Remove Battery 1 of 3: 5 단계, 이미지 2개 중 1개 Acer Aspire a515-46 SSD Replacement, Remove Battery 1 of 3: 5 단계, 이미지 2개 중 2개
    • Remove the two pieces of tape holding the battery connector and wires.
  6. Acer Aspire a515-46 SSD Replacement, Remove Battery 2 of 3: 6 단계, 이미지 3개 중 1개 Acer Aspire a515-46 SSD Replacement, Remove Battery 2 of 3: 6 단계, 이미지 3개 중 2개 Acer Aspire a515-46 SSD Replacement, Remove Battery 2 of 3: 6 단계, 이미지 3개 중 3개
    • Using your fingernails, pinch the battery connector on both sides and pull it straight back until it is removed from the socket.
  7. Acer Aspire a515-46 SSD Replacement, Remove Battery 3 of 3: 7 단계, 이미지 2개 중 1개 Acer Aspire a515-46 SSD Replacement, Remove Battery 3 of 3: 7 단계, 이미지 2개 중 2개
    • Pull up and remove the battery from the compartment.
  8. Acer Aspire a515-46 SSD Replacement, Replace SSD 1 of 3: 8 단계, 이미지 2개 중 1개 Acer Aspire a515-46 SSD Replacement, Replace SSD 1 of 3: 8 단계, 이미지 2개 중 2개
    • Use a small Philips head screwdriver to remove the screw holding the bottom of the SSD.
  9. Acer Aspire a515-46 SSD Replacement, Replace SSD 2 of 3: 9 단계, 이미지 2개 중 1개 Acer Aspire a515-46 SSD Replacement, Replace SSD 2 of 3: 9 단계, 이미지 2개 중 2개
    • Pull the SSD straight back until it is removed from the socket.
  10. Acer Aspire a515-46 SSD Replacement, Replace SSD 3 of 3: 10 단계, 이미지 2개 중 1개 Acer Aspire a515-46 SSD Replacement, Replace SSD 3 of 3: 10 단계, 이미지 2개 중 2개
    • Insert the new SSD into the socket, making sure that the notch is on the right side of the SSD.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Am Persand
회원 가입일: 04/11/23
211 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 534
