주요 콘텐츠로 건너뛰기
Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement
필요한 것
  1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: 1 단계, 이미지 1/2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: 1 단계, 이미지 2/2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: 3 단계, 이미지 1/2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 4 단계, 이미지 1/2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 4 단계, 이미지 2/2
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 5 단계, 이미지 1/1
    • Remove the battery.
  6. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: 6 단계, 이미지 1/2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: 6 단계, 이미지 2/2
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 7 단계, 이미지 1/3 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 7 단계, 이미지 2/3 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 7 단계, 이미지 3/3
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
결론
Jessica Beckford
회원 가입일: 02/12/18
527 평판
안내서 4개 작성하였습니다
USF Tampa, Team S15-G4, Boczar Spring 2018 USF Tampa, Team S15-G4, Boczar Spring 2018 회원
USFT-BOCZAR-S18S15G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 6
30일 전: 7
전체 시간: 183
