필요한 것
Close your Chromebook and flip it over on its back.
Remove the 12 screws holding on the back cover with a Philips #1 screwdriver.
Use a spudger or pry tool to release the clips and remove the back cover.
Pull both black tabs on the sides of the connector directly forward to release the cable.
Pull the keyboard flex cable out of its connector.
Flip the white latch upwards toward the motherboard.
Pull the touchpad flex cable out of its connector.
Flip the black latch upwards toward the cable.
Pull the cable to the left
거의 끝나갑니다!
Congratulations! You just replaced your Chromebook's motherboard.
결론
