주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
To avoid electric discharge and possible damage to internal components, the battery should be disconnected from the motherboard as a prerequisite to replacing other parts. You will not need to remove or replace any other parts of the device in order to do so. For this guide, you will need an anti-static mat to avoid electrostatic discharge, a Phillips #0 screwdriver head, a spudger (either plastic or metal) and tweezers to handle small parts. The process is relatively simple and should only take about 10 minutes.
  1. Flip the computer over and use a Phillips #0 screwdriver head to remove the 13 2.5 mm bottom cover screws.
    • Flip the computer over and use a Phillips #0 screwdriver head to remove the 13 2.5 mm bottom cover screws.
  2. Use your spudger to carefully pry the bottom cover away from the palm rest assembly.
    • Use your spudger to carefully pry the bottom cover away from the palm rest assembly.
    • Don't pull the cover away too hard once it's apart from the assembly because the headphone jack cable is still attached to the bottom cover.
  3. Use the pointed side of the spudger to disconnect the headphone jack cable from the motherboard and completely remove the bottom cover.
    • Use the pointed side of the spudger to disconnect the headphone jack cable from the motherboard and completely remove the bottom cover.
  4. Use the pointed side of the spudger to disconnect the battery cable from the motherboard.
    • Use the pointed side of the spudger to disconnect the battery cable from the motherboard.
  5. Use a Phillips #0 screwdriver head to remove the two 2.5 mm #1 battery screws. Use your hands to remove the battery by gently picking it up.
    • Use a Phillips #0 screwdriver head to remove the two 2.5 mm #1 battery screws.
    • Use your hands to remove the battery by gently picking it up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Arin Forstadt
회원 가입일: 2019년 02월 05일
407 평판
안내서 1개 작성함
University of Michigan, Team S1-G1, Li Winter 2019 University of Michigan, Team S1-G1, Li Winter 2019 회원
UMIC-LI-W19S1G1
4 회원들
안내서 1개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 27
전체 시간: 451
