주요 콘텐츠로 건너뛰기
Acer Chromebook 14 CB3-431-C7EX Battery Replacement
필요한 것
  1. Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • There are several clips holding the cover in place.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 2 단계, 이미지 3개 중 1개 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 2 단계, 이미지 3개 중 2개 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the battery's connector from the motherboard. The connector should slide out toward the battery.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to unscrew the two 5.5mm screws from the battery housing.
  4. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 4 단계, 이미지 1개 중 1개
    • While lifting the connector side of the battery, slide the battery towards the center of the laptop.
    • Be mindful of the tabs on the bottom of the battery housing (shown in picture). These need to be underneath slots when reinserting the battery back into the laptop.
    • Remove the battery from the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Thomas Carling
회원 가입일: 01/30/20
570 평판
안내서 4개를 작성함
1가이드 댓글
clear and concise
good instructions
battery can be found for less than half that cost online
mapatouli - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 17
전체 시간: 2,557
