주요 콘텐츠로 건너뛰기
Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement
필요한 것
  1. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: 1 단계, 이미지 3개 중 1개 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: 1 단계, 이미지 3개 중 2개 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: 1 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a Phillips #0 screwdriver to unscrew the four 5.5mm screws from the screen brackets.
    • Use tweezers to set aside the ground tape (tan) and the electrical tape (black). This may need to be reconnected during reassembly.
  3. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 3 단계, 이미지 3개 중 1개 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 3 단계, 이미지 3개 중 2개 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Use tweezers to detach the webcam connectors from the motherboard.
    • Keep in mind that the black cable connects to the left pin and the white cable connects to the right pin.
    • There may be electric tape covering the connectors. Use tweezers to set aside the tape for reuse.
  4. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 4 단계, 이미지 3개 중 1개 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 4 단계, 이미지 3개 중 2개 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Disconnect the display panel connector from the motherboard. The connector should slide out away from the motherboard.
    • Be sure to remove the connector evenly from the port.
  5. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 5 단계, 이미지 3개 중 1개 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 5 단계, 이미지 3개 중 2개 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • To remove the lid from the laptop, pivot each end on the hinge and lift the rest of the laptop up and away from the lid.
    • Remove the display assembly from the laptop case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Thomas Carling
회원 가입일: 01/30/20
570 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 16
전체 시간: 1,078
