주요 콘텐츠로 건너뛰기
Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement
필요한 것
  1. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: 1 단계, 이미지 1/3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: 1 단계, 이미지 2/3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: 1 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 2 단계, 이미지 1/2 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a Phillips #0 screwdriver to unscrew the four 5.5mm screws from the screen brackets.
    • Use tweezers to set aside the ground tape (tan) and the electrical tape (black). This may need to be reconnected during reassembly.
  3. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 3 단계, 이미지 1/3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 3 단계, 이미지 2/3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 3 단계, 이미지 3/3
    • Use tweezers to detach the webcam connectors from the motherboard.
    • Keep in mind that the black cable connects to the left pin and the white cable connects to the right pin.
    • There may be electric tape covering the connectors. Use tweezers to set aside the tape for reuse.
  4. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 4 단계, 이미지 1/3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 4 단계, 이미지 2/3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 4 단계, 이미지 3/3
    • Disconnect the display panel connector from the motherboard. The connector should slide out away from the motherboard.
    • Be sure to remove the connector evenly from the port.
  5. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 5 단계, 이미지 1/3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 5 단계, 이미지 2/3 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 5 단계, 이미지 3/3
    • To remove the lid from the laptop, pivot each end on the hinge and lift the rest of the laptop up and away from the lid.
    • Remove the display assembly from the laptop case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Thomas Carling
회원 가입일: 01/30/20
552 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 803
