주요 콘텐츠로 건너뛰기
Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement
필요한 것
  1. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 1/3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 2/3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 2 단계, 이미지 1/3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 2 단계, 이미지 2/3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 2 단계, 이미지 3/3
    • Use a spudger to disconnect the speaker connector from the bottom of the sound card. The connector should slide out toward the left speaker's housing.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 3 단계, 이미지 1/2 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 3 단계, 이미지 2/2
    • Use a spudger to carefully disconnect the ribbon connector from the right side of the sound card. The connector should slide out toward the motherboard.
    • Be sure to remove the connector evenly from the port, as the ribbon connector may be fragile.
  4. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 4 단계, 이미지 1/2 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to unscrew the two 4mm screws.
  5. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 5 단계, 이미지 1/1
    • Slide the sound card towards the motherboard until the headphone jack is out of its hole on the side of the laptop.
    • Lift the sound card directly up from the laptop to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ryan M
회원 가입일: 01/30/20
213 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 591
