주요 콘텐츠로 건너뛰기
Acer Chromebook 14 CB3-431-C7EX Speakers Replacement
필요한 것
  1. Acer Chromebook 14 CB3-431-C7EX Speakers Replacement, Speakers: 1 단계, 이미지 1/3 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement, Speakers: 1 단계, 이미지 2/3 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement, Speakers: 1 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws and then remove the cover.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 2 단계, 이미지 1/3 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 2 단계, 이미지 2/3 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 2 단계, 이미지 3/3
    • Use a spudger to disconnect the speaker connector from the bottom of the sound card. The connector should slide out toward the left speaker's housing.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 3 단계, 이미지 1/2 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 3 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to unscrew the four 5.5mm screws from the battery housing.
  4. Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 4 단계, 이미지 1/3 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 4 단계, 이미지 2/3 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: 4 단계, 이미지 3/3
    • Lift the left and right speakers directly upward from the laptop to remove them.
    • Unwind the wire connecting the two speakers from the slalom.
    • The connection between the wire and the speakers may be fragile.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Thomas Carling
회원 가입일: 01/30/20
552 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 331
