주요 콘텐츠로 건너뛰기
Acer Chromebook 15 C910-C453 Battery Replacement
필요한 것
  1. Acer Chromebook 15 C910-C453 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Battery Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Battery Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the battery.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jacob Rakestraw
회원 가입일: 04/17/17
419 평판
안내서 4개를 작성함
Cal Poly, Team S15-G1, Banghart Spring 2017 Cal Poly, Team S15-G1, Banghart Spring 2017 회원
CPSU-BANGHART-S17S15G1
5 회원들
안내서 12개를 작성함
댓글 한 개
Jacob, WELL DONE. I have an Acer 15 C910-C451 that was driving me nuts. It would hold a battery charge but only up to 17% then drain fairly rapidly duing use. It didn’t make sense that a battery would have a set of bad cells but that is probably exactly what was the problem. So new battery in hand and a set of tools designed not to harm the case I followed your instructions to the letter. BINGO ! At this moment the unit is charging from a start of 87% it is now at 96% and climbing. Thanks for the detailed pics of the process.
Thomas Revell - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 10,274
