주요 콘텐츠로 건너뛰기
Acer Chromebook 15 C910-C453 Fan Replacement
필요한 것
  1. Acer Chromebook 15 C910-C453 Fan Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Fan Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Fan Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Fan Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Fan Replacement, Fan: 6 단계, 이미지 1개 중 1개
    • Unscrew the following Phillips #1 screws:
    • Two black 4mm Phillips screws located on the fan.
    • Four copper 4mm Phillips screws located on the heat sink.
  7. Acer Chromebook 15 C910-C453 Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the fan from the motherboard by pulling down on the wire connector with two iFixit Opening Tools.
  8. Acer Chromebook 15 C910-C453 Fan Replacement: 8 단계, 이미지 1개 중 1개
    • Lift up the fan while unwrapping the black and white wires from around the fan.
    • Do not pull wires off of the motherboard.
    • Remove the fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jacob Rakestraw
회원 가입일: 04/17/17
419 평판
안내서 4개를 작성함
Cal Poly, Team S15-G1, Banghart Spring 2017 Cal Poly, Team S15-G1, Banghart Spring 2017 회원
CPSU-BANGHART-S17S15G1
5 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 13
전체 시간: 536
