주요 콘텐츠로 건너뛰기
Acer Chromebook 15 C910-C453 Trackpad Replacement
필요한 것
  1. Acer Chromebook 15 C910-C453 Trackpad Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Trackpad Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Trackpad Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Trackpad Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Trackpad Replacement: 3 단계, 이미지 2개 중 2개
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Trackpad Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Trackpad Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Trackpad Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Trackpad Replacement, Trackpad: 6 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Trackpad Replacement, Trackpad: 6 단계, 이미지 2개 중 2개
    • Unscrew the seven 6mm Phillips screws located around the trackpad.
  7. Acer Chromebook 15 C910-C453 Trackpad Replacement: 7 단계, 이미지 1개 중 1개
    • Lift up the rectangular metal plate at the base.
  8. Acer Chromebook 15 C910-C453 Trackpad Replacement: 8 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Trackpad Replacement: 8 단계, 이미지 2개 중 2개
    • Flip the black bar where the white ribbon is connected to the trackpad upward to unlock it.
    • Gently pull the white ribbon away from the trackpad.
  9. Acer Chromebook 15 C910-C453 Trackpad Replacement: 9 단계, 이미지 2개 중 1개 Acer Chromebook 15 C910-C453 Trackpad Replacement: 9 단계, 이미지 2개 중 2개
    • Gently lift the trackpad up and pull towards you to remove the trackpad.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mia von Knorring
회원 가입일: 04/17/17
443 평판
안내서 1개를 작성함
Cal Poly, Team S15-G1, Banghart Spring 2017 Cal Poly, Team S15-G1, Banghart Spring 2017 회원
CPSU-BANGHART-S17S15G1
5 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 433
