주요 콘텐츠로 건너뛰기
Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement
필요한 것
  1. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 1개 중 1개
    • Place the device on a flat surface with the bottom facing upwards.
  2. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the eighteen 6 mm screws from bottom of the device using a Phillips #0 screwdriver.
  3. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 2개
    • With the plastic opening tool, pry along the edges of the bottom slowly to separate the back cover.
    • Be careful not to damage or crack the back cover of the device.
  4. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully remove the back cover.
  5. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: 5 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: 5 단계, 이미지 2개 중 2개
    • Locate the Wi-Fi card. It will be white chip beside the motherboard.
    • Remove the 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
  6. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: 6 단계, 이미지 3개 중 1개 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: 6 단계, 이미지 3개 중 2개 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: 6 단계, 이미지 3개 중 3개
    • Gently grab the edges of the Wi-Fi card and pull it out from the motherboard.
    • Carefully remove the two coaxial antenna cables that attach the Wi-Fi card to the motherboard. One is black and the other is white.
    • Have your new replacement Wi-Fi card ready to place back in the slot.
결론
작성자
1다른 기여자 명과 함께
Avinesh Mohanaranjan
회원 가입일: 09/16/21
183 평판
안내서 1개를 작성함
York University, Team E-17, Melo-Thaiss Fall 2021 York University, Team E-17, Melo-Thaiss Fall 2021 회원
YORK-MELO-THAISS-F21SEG17
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 23
전체 시간: 1,135
