주요 콘텐츠로 건너뛰기
Acer Chromebook 15 CB5-571-C09S Battery Replacement
필요한 것
  1. Acer Chromebook 15 CB5-571-C09S Battery Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Battery Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Battery Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Battery Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: 5 단계, 이미지 3개 중 1개 Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: 5 단계, 이미지 3개 중 2개 Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: 5 단계, 이미지 3개 중 3개
    • The battery is the large black rectangle located in the bottom center of the device.
    • Unscrew the single black 5 mm PH00 Phillips head screw holding the battery in place located at the top right corner of the battery.
  6. Acer Chromebook 15 CB5-571-C09S Battery Replacement: 6 단계, 이미지 3개 중 1개 Acer Chromebook 15 CB5-571-C09S Battery Replacement: 6 단계, 이미지 3개 중 2개 Acer Chromebook 15 CB5-571-C09S Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Disconnect the battery connector from the motherboard using two plastic opening tools.
    • The battery connector is the white "plug" that connects the battery to the motherboard with rainbow colored wires attached to it.
    • Use two of the plastic opening tools on either edge of the battery connector and carefully pull out the battery connector out from the motherboard.
  7. Acer Chromebook 15 CB5-571-C09S Battery Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Once the battery has been disconnected from the motherboard it can easily be removed from the device.
    • Grab the top edge of the battery and carefully pull it up and out of the device towards you.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sakiynah Howard
회원 가입일: 10/17/17
1,000 평판
안내서 6개를 작성함
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 UMass Dartmouth, Team S1-G3, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G3
3 회원들
안내서 12개를 작성함
댓글 2개
Where do you get the plastic opening tools
Kelly Robledo - 답글
Instructions were perfect. Used a putty knife to pry off the back
Naomi Harrison - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 16
전체 시간: 4,204
