주요 콘텐츠로 건너뛰기
Acer Chromebook 15 CB5-571-C09S Screen Replacement
필요한 것
  1. Acer Chromebook 15 CB5-571-C09S Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • Wedge one of the plastic opening tool in the inside of the screen cover and run it along the inside perimeter of the screen.
  2. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Wedge the plastic opening tool inside the back of the screen cover and run along the perimeter of the screen.
  3. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the screen cover from the screen.
    • Pry off a pair of small covers at the back of the hinges first.
    • Carefully grab the edges of the screen cover from opposite ends and pull off the screen towards you.
  4. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 4 단계, 이미지 3개 중 1개 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 4 단계, 이미지 3개 중 2개 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Unscrew the four 3 mm PH00 Phillips head screws located on the inside corners of the screen.
    • Be sure to unscrew the inner screws attached to the screen and not the outer screws.
  5. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Grab the edges of the screen and pull it out towards you.
    • Do not try to remove the screen from the device at this point. There are still connections in the back that need to be disconnected before the screen can be removed.
  6. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Take out screen from top part of the device and lay it down flat on the key board.
  7. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 7 단계, 이미지 3개 중 1개 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 7 단계, 이미지 3개 중 2개 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the screen connector from the back of the screen.
    • The screen connector is a "plug" that is connected to the back of the screen with a grey wire.
    • The screen connector is attached to the back of the screen with a sticker.
    • Peel and remove the sticker connecting the screen connector to the screen.
  8. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 8 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the screen back up from the keyboard and remove from the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sakiynah Howard
회원 가입일: 10/17/17
1,024 평판
안내서 6개를 작성함
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 UMass Dartmouth, Team S1-G3, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G3
3 회원들
안내서 12개를 작성함
1가이드 댓글
Where can I find the replacement screen?
Riccardo Rigamondi - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 2,326
