주요 콘텐츠로 건너뛰기
Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement
필요한 것
  1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: 5 단계, 이미지 3개 중 1개 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: 5 단계, 이미지 3개 중 2개 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: 5 단계, 이미지 3개 중 3개
    • The Solid State Drive is the blue chip locate right beneath the fan.
    • Unscrew the 3 mm PH00 Phillips head screw located on the left side of the SSD.
  6. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 6 단계, 이미지 2개 중 1개 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Grab the top and bottom edges of the SSD and carefully pull it out from the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sakiynah Howard
회원 가입일: 10/17/17
1,024 평판
안내서 6개를 작성함
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 UMass Dartmouth, Team S1-G3, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G3
3 회원들
안내서 12개를 작성함
1가이드 댓글
Mine has a positive and neutral wire moving away from the SSD, and removing the chip entirely hasn't impeded operation whatsoever despite me doing it to force developer mode.
Helios Bajammin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 29
전체 시간: 3,840
