주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Acer Chromebook C710 Back Cover Replacement
필요한 것
  1. Acer Chromebook C710 Back Cover Replacement, Battery: 1 단계, 이미지 1/2 Acer Chromebook C710 Back Cover Replacement, Battery: 1 단계, 이미지 2/2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710 Back Cover Replacement: 2 단계, 이미지 1/2 Acer Chromebook C710 Back Cover Replacement: 2 단계, 이미지 2/2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710 Back Cover Replacement, Back Cover: 3 단계, 이미지 1/1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710 Back Cover Replacement: 4 단계, 이미지 1/2 Acer Chromebook C710 Back Cover Replacement: 4 단계, 이미지 2/2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Bradley Pavy
회원 가입일: 09/30/13
1,257 평판
안내서 6개 작성하였습니다
Cal Poly, Team 13-3, Forte Fall 2013 Cal Poly, Team 13-3, Forte Fall 2013 회원
CPSU-FORTE-F13S13G3
5 회원들
안내서 14개 작성하였습니다
댓글 한 개
Once you have the back cover off, you can insert aluminum foil into a tiny connector, which will allow you to flash the BIOS and boot any operating system, not just ChromeOS. Using this method, I completely wiped ChromeOS from my C710 and installed Ubuntu 16.04 LTS. Definitely worth it, because now I have a sub-$300 Linux netbook with a removable battery, standard keyboard with CAPS lock (most Chromebooks don't), and no ugly Windows key.
Uncle Happy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 6,289
