소개
As a computer is used, it generates heat. The cooling fan pulls air through the device to cool it down. If it becomes clogged with dust or breaks, the computer will overheat.
필요한 것
Place the laptop on a flat surface with the bottom side facing up.
Place the tip of a spudger or finger into the hole on the battery release slider.
Use the screwdriver to pierce the warranty sticker.
Unscrew and remove the #0 6mm Phillips screw and set it aside.
Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
Remove the SD card or placeholder by pressing the card in until it clicks and pops out.
Pull the card out.
Remove the screws.
Sixteen #0 6mm Phillips screws
One #0 3mm screw
다른 6명이 해당 안내서를 완성하였습니다.
