주요 콘텐츠로 건너뛰기
Acer Chromebook C710-2847 Screen Replacement
필요한 것
  1. Acer Chromebook C710-2847 Screen Replacement, Battery: 1 단계, 이미지 1/2 Acer Chromebook C710-2847 Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Screen Replacement: 2 단계, 이미지 1/2 Acer Chromebook C710-2847 Screen Replacement: 2 단계, 이미지 2/2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Screen Replacement, Screen: 3 단계, 이미지 1/3 Acer Chromebook C710-2847 Screen Replacement, Screen: 3 단계, 이미지 2/3 Acer Chromebook C710-2847 Screen Replacement, Screen: 3 단계, 이미지 3/3
    • Open the laptop, keeping the screen on the table.
    • CAUTION: Only use the spudger on the outside of the device. Don't insert it where the bezel meets the screen
    • Use a spudger to unclip the top left and right sides of the bezel. You should feel and hear the clips releasing as you do this.
    • Turn the device around 180 degrees, keeping the screen on the table. Use the spudger on the bottom of the screen to unclip the bezel between the hinges.
  4. Acer Chromebook C710-2847 Screen Replacement: 4 단계, 이미지 1/2 Acer Chromebook C710-2847 Screen Replacement: 4 단계, 이미지 2/2
    • Lift the bezel one inch off the top corners of the screen.
    • Gently pull the plastic bezel toward you.
    • Set the bezel aside.
  5. Acer Chromebook C710-2847 Screen Replacement: 5 단계, 이미지 1/2 Acer Chromebook C710-2847 Screen Replacement: 5 단계, 이미지 2/2
    • Unscrew the four black #0 3mm Phillips screws holding down the screen.
    • Lift up the small pieces of black tape at the bottom center of the screen near the keyboard.
  6. Acer Chromebook C710-2847 Screen Replacement: 6 단계, 이미지 1/3 Acer Chromebook C710-2847 Screen Replacement: 6 단계, 이미지 2/3 Acer Chromebook C710-2847 Screen Replacement: 6 단계, 이미지 3/3
    • Lift up the screen from the silver tabs at the top and flip it over to rest on top of the keyboard.
    • Carefully unwrap the narrow black tape from around the ribbon cable connection.
    • Pull off the clear tape from the ribbon cable connection.
  7. Acer Chromebook C710-2847 Screen Replacement: 7 단계, 이미지 1/3 Acer Chromebook C710-2847 Screen Replacement: 7 단계, 이미지 2/3 Acer Chromebook C710-2847 Screen Replacement: 7 단계, 이미지 3/3
    • Pull out the ribbon cable.
    • Remove any remaining tape holding the screen to the laptop.
결론
To reassemble your device, follow these instructions in reverse order. Be sure to tape the cable back to the screen to avoid display problems.
다른 33명이 해당 안내서를 완성하였습니다.
Bradley Pavy
회원 가입일: 09/30/13
1,257 평판
안내서 6개 작성하였습니다
Cal Poly, Team 13-3, Forte Fall 2013 Cal Poly, Team 13-3, Forte Fall 2013 회원
CPSU-FORTE-F13S13G3
5 회원들
안내서 14개 작성하였습니다
댓글 8개
I am 69 years old and bought myself and 4 grandchildren Acer Chromebooks. I heard the screen messing up was quite common. So when my screen went first, I knew I had to learn to fix it, or spend another small fortune if they all broke down. So here I am. The screen is out..next adventure..putting a new one in. Will return here to do that. Thanks for the site.
Patricia Hadley - 답글
Worked perfectly. Replaced my daughters screen in about 15 minutes. Thank you.
Liam - 답글
Great guide. Didn't realize it was that simple...i'd like a little information on which screen was purchased for this model.
Thanks!
Adam Johnson - 답글
I like it. The link for the screen is dead for me but I will find one.
Spencer Saunders - 답글
Thanks for this. Just repaired 3 laptops for my classroom! Super easy.
Andrew Davis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 29
전체 시간: 39,878
