소개
The wireless card is responsible for connecting the Chromebook to Wi-Fi networks and Bluetooth devices.
도구
부품
Place the laptop on a flat surface with the bottom side facing up.
Place the tip of a spudger or finger into the hole on the battery release slider.
Use the screwdriver to pierce the warranty sticker.
Unscrew and remove the #0 6mm Phillips screw and set it aside.
Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
다른 한 분이 해당 안내서를 완성하였습니다.
