소개
The wireless card is responsible for connecting the Chromebook to Wi-Fi networks and Bluetooth devices.
필요한 것
Place the laptop on a flat surface with the bottom side facing up.
Place the tip of a spudger or finger into the hole on the battery release slider.
Use the screwdriver to pierce the warranty sticker.
Unscrew and remove the #0 6mm Phillips screw and set it aside.
Bradley,
If I replace the chrome os Hard drive with one that has a Linux distro already installed will the linux work normally or is there something built in to stop it.
It's something I do with an old dell I use for checking out distros.
Regards,
Jack
I guess it's too late to answer this question now, but C710 is not IBM PC-compatible so standard linux distros do not run normally on it without any modifications.
You can flash a IBM PC-compatible bootloader(coreboot+SEABIOS) on it to run other linux distros.
cdac1234 -
Any suggested source for getting the 4 Gb RAM upgrade? Does this RAM have a model number?
rwells78 -
What is the hard drive called, or it's specific name, so that I may search around for a replacement, before taking my laptop apart?
Mine is a Seagate ST320L T020
do not so what the second picture shows and leave the battery in!
Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
다른 2명이 해당 안내서를 완성하였습니다.
