주요 콘텐츠로 건너뛰기
Acer Chromebook C710-2833 Hard Drive Replacement
필요한 것
  1. Acer Chromebook C710-2833 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook C710-2833 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the screw and cover safely to the side for now.
  3. Acer Chromebook C710-2833 Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook C710-2833 Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Locate the hard drive.
    • Locate the four 3 mm Phillips #00 screws on each corner of the hard drive.
    • Take your driver with the PH00 bit attached and unscrew all four screws.
    • Place the screws off to the side for now.
  5. Acer Chromebook C710-2833 Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 Acer Chromebook C710-2833 Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Once all the screws are out, gently pull the hard drive out as pictured.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nicholas Latorre
회원 가입일: 09/28/17
558 평판
안내서 5개를 작성함
USF Tampa, Team S1-G6, Nance Fall 2017 USF Tampa, Team S1-G6, Nance Fall 2017 회원
USFT-NANCE-F17S1G6
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 27
전체 시간: 1,807
