주요 콘텐츠로 건너뛰기
Acer Chromebook C710-2833 RAM Module Replacement
필요한 것
  1. Acer Chromebook C710-2833 RAM Module Replacement, RAM Module: 1 단계, 이미지 1/1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 RAM Module Replacement: 2 단계, 이미지 1/2 Acer Chromebook C710-2833 RAM Module Replacement: 2 단계, 이미지 2/2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the screw and cover safely to the side for now.
  3. Acer Chromebook C710-2833 RAM Module Replacement: 3 단계, 이미지 1/2 Acer Chromebook C710-2833 RAM Module Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 RAM Module Replacement: 4 단계, 이미지 1/3 Acer Chromebook C710-2833 RAM Module Replacement: 4 단계, 이미지 2/3 Acer Chromebook C710-2833 RAM Module Replacement: 4 단계, 이미지 3/3
    • Locate the RAM module.
    • Squeeze the two metal clips on the sides of the RAM module to pop the RAM out.
    • Carefully remove from the slot.
    • When reassembling, stick RAM into slot and push down until a clicking sound is heard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicholas Latorre
회원 가입일: 09/28/17
558 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G6, Nance Fall 2017 USF Tampa, Team S1-G6, Nance Fall 2017 회원
USFT-NANCE-F17S1G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 803
