주요 콘텐츠로 건너뛰기
Acer Chromebook C710-2833 Wifi Card Replacement
필요한 것
  1. Acer Chromebook C710-2833 Wifi Card Replacement, Wifi Card: 1 단계, 이미지 1/1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Wifi Card Replacement: 2 단계, 이미지 1/2 Acer Chromebook C710-2833 Wifi Card Replacement: 2 단계, 이미지 2/2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 Wifi Card Replacement: 3 단계, 이미지 1/2 Acer Chromebook C710-2833 Wifi Card Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 Wifi Card Replacement: 4 단계, 이미지 1/1
    • Locate the 3 mm Phillips #00 screw on the wireless card port.
    • Unscrew the screw and place it aside for now.
  5. Acer Chromebook C710-2833 Wifi Card Replacement: 5 단계, 이미지 1/3 Acer Chromebook C710-2833 Wifi Card Replacement: 5 단계, 이미지 2/3 Acer Chromebook C710-2833 Wifi Card Replacement: 5 단계, 이미지 3/3
    • Safely remove the wireless card by pulling it out of the bottom of the port.
    • Lastly, disconnect the two white and black wire connectors attached to the wireless card.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicholas Latorre
회원 가입일: 09/28/17
558 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G6, Nance Fall 2017 USF Tampa, Team S1-G6, Nance Fall 2017 회원
USFT-NANCE-F17S1G6
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Replaced the original wifi card, how do you get Chrome OS to recognize, or find and download driver for Intel AC 7260 wifi card?
Thanks.
When Ze - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 12
전체 시간: 756
