주요 콘텐츠로 건너뛰기
Acer Chromebook C710-2847 Back Cover Replacement
필요한 것
  1. Acer Chromebook C710-2847 Back Cover Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Chromebook C710-2847 Back Cover Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Back Cover Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook C710-2847 Back Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Back Cover Replacement, Acer Chromebook C710-2847 Back Cover Replacement: 3 단계, 이미지 1개 중 1개
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710-2847 Back Cover Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook C710-2847 Back Cover Replacement: 4 단계, 이미지 2개 중 2개
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Bradley Pavy
회원 가입일: 09/30/13
1,257 평판
안내서 6개를 작성함
Cal Poly, Team 13-3, Forte Fall 2013 Cal Poly, Team 13-3, Forte Fall 2013 회원
CPSU-FORTE-F13S13G3
5 회원들
안내서 14개를 작성함
댓글 한 개
Once you have the back cover off, you can insert aluminum foil into a tiny connector, which will allow you to flash the BIOS and boot any operating system, not just ChromeOS. Using this method, I completely wiped ChromeOS from my C710 and installed Ubuntu 16.04 LTS. Definitely worth it, because now I have a sub-$300 Linux netbook with a removable battery, standard keyboard with CAPS lock (most Chromebooks don't), and no ugly Windows key.
Uncle Happy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 10
전체 시간: 6,390
