주요 콘텐츠로 건너뛰기
Acer Chromebook C710-2847 Battery Replacement
필요한 것
  1. Acer Chromebook C710-2847 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Chromebook C710-2847 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Battery Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook C710-2847 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Adam Whitmarsh
회원 가입일: 09/30/13
1,059 평판
안내서 1개를 작성함
Cal Poly, Team 13-3, Forte Fall 2013 Cal Poly, Team 13-3, Forte Fall 2013 회원
CPSU-FORTE-F13S13G3
5 회원들
안내서 14개를 작성함
댓글 5개
I actually used a ball point pin instead of a spudger (its dark, I'm female and I am not walking to Office Max in this neighborhood by myself). And voici, the battery came off. Now to see if the damned computer will reboot.
Daphne Macklin - 답글
I have a C710-2856, which uses a 14.8V battery. All of the extended batteries say they won't work on the 14.8V battery .Does anyone know of an extended battery that WOULD work with the 14.8V version of this Chromebook. I can up the RAM to 16GB, and I can put any SSD, but the only weakness left is the short battery life.
Tom Dison - 답글
I wish I had an answer for you! I'm looking into the same thing. All the extended batteries are 11.1 v and not compatible with the 14.8 v need of the C710-2856. Did you ever get an answer to this? perhaps elsewhere? Thanks!
Cornell Gunter -
i have a C710-2815? what kind of battery do i need for a replacement
sudanna soetome - 답글
I ordered this battery before seeing this. Not only is voltage incorrect, but it does not latch.
https://www.amazon.com/gp/product/B00XDT...
Slides on, but connector mismatch and will not lock into place.
Sending back.
Also the BUY PARTS amazon button at the top right of this article is a 404 error.
When Ze - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 18
전체 시간: 30,782
