소개
If your screen breaks or has dead pixels, the most cost effective solution is to replace the screen.
Place the laptop on a flat surface with the bottom side facing up.
Place the tip of a spudger or finger into the hole on the battery release slider.
Open the laptop, keeping the screen on the table.
Use a spudger to unclip the top left and right sides of the bezel. You should feel and hear the clips releasing as you do this.
Turn the device around 180 degrees, keeping the screen on the table. Use the spudger on the bottom of the screen to unclip the bezel between the hinges.
To reassemble your device, follow these instructions in reverse order. Be sure to tape the cable back to the screen to avoid display problems.
다른 33명이 해당 안내서를 완성하였습니다.
댓글 8개
I am 69 years old and bought myself and 4 grandchildren Acer Chromebooks. I heard the screen messing up was quite common. So when my screen went first, I knew I had to learn to fix it, or spend another small fortune if they all broke down. So here I am. The screen is out..next adventure..putting a new one in. Will return here to do that. Thanks for the site.
Great guide. Didn't realize it was that simple...i'd like a little information on which screen was purchased for this model.
Thanks!
I like it. The link for the screen is dead for me but I will find one.
Thanks for this. Just repaired 3 laptops for my classroom! Super easy.
Works well! I work at a school and needed to replace the screens to 10 units. Works great!
