주요 콘텐츠로 건너뛰기
Acer Chromebook C710-2847 Wireless Card Replacement
필요한 것
  1. Acer Chromebook C710-2847 Wireless Card Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Chromebook C710-2847 Wireless Card Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Wireless Card Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook C710-2847 Wireless Card Replacement: 2 단계, 이미지 2개 중 2개
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Wireless Card Replacement, Acer Chromebook C710-2847 Back Cover Replacement: 3 단계, 이미지 1개 중 1개
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710-2847 Wireless Card Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook C710-2847 Wireless Card Replacement: 4 단계, 이미지 2개 중 2개
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
  5. Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: 5 단계, 이미지 3개 중 1개 Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: 5 단계, 이미지 3개 중 2개 Acer Chromebook C710-2847 Wireless Card Replacement, Wireless Card: 5 단계, 이미지 3개 중 3개
    • Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
  6. Acer Chromebook C710-2847 Wireless Card Replacement: 6 단계, 이미지 1개 중 1개
    • Unscrew the black #0 3mm Phillips screw at the top right of the wireless card.
  7. Acer Chromebook C710-2847 Wireless Card Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook C710-2847 Wireless Card Replacement: 7 단계, 이미지 2개 중 2개
    • The wireless card will spring up.
    • Pull the wireless card up and out to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Bradley Pavy
회원 가입일: 09/30/13
1,257 평판
안내서 6개를 작성함
Cal Poly, Team 13-3, Forte Fall 2013 Cal Poly, Team 13-3, Forte Fall 2013 회원
CPSU-FORTE-F13S13G3
5 회원들
안내서 14개를 작성함
댓글 한 개
If you replace the original wifi card, how do you get Chrome OS to recognize, or find and download driver for Intel AC 7260 wifi card?
Thanks.
When Ze - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 6,112
