이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Place the laptop on a flat surface with the bottom side facing up.
Place the tip of a spudger or finger into the hole on the battery release slider.
Use the spudger to move the slider to the right and hold it there.
With the slider held, use your other hand to pull the battery back away from the laptop.
Use the screwdriver to pierce the warranty sticker.
Unscrew and remove the #0 6mm Phillips screw and set it aside.
Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
Lift on the front edge to remove the panel.
Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
Unscrew the black #0 3mm Phillips screw at the top right of the wireless card.
The wireless card will spring up.
Pull the wireless card up and out to remove it.
다른 2명이 해당 안내서를 완성하였습니다.
