주요 콘텐츠로 건너뛰기
Acer Chromebook C710-2856 Hard Drive Replacement
필요한 것
  1. Acer Chromebook C710-2856 Hard Drive Replacement, Removing Back Cover: 1 단계, 이미지 1/2 Acer Chromebook C710-2856 Hard Drive Replacement, Removing Back Cover: 1 단계, 이미지 2/2
    • Remove the one 4.3mm Phillips #1 screw holding the back cover on.
  2. Acer Chromebook C710-2856 Hard Drive Replacement, Unscrewing the Drive: 2 단계, 이미지 1/1
    • Remove the four 2.8mm Phillips #000 screws holding the drive onto the case.
  3. Acer Chromebook C710-2856 Hard Drive Replacement, Uncovering the Pins: 3 단계, 이미지 1/1
    • Gently pull the foam protector away from the pin connectors
  4. Acer Chromebook C710-2856 Hard Drive Replacement, Disconnecting the Drive: 4 단계, 이미지 1/2 Acer Chromebook C710-2856 Hard Drive Replacement, Disconnecting the Drive: 4 단계, 이미지 2/2
    • Gently pull the drive up and away to disconnect the hard drive from its seat
  5. Acer Chromebook C710-2856 Hard Drive Replacement, Removed Drive and Pieces: 5 단계, 이미지 1/1
    • Fully removed hard drive, screws, and foam cover
결론
Josh Rowell
회원 가입일: 10/10/17
146 평판
안내서 1개 작성함
USF Tampa, Team S6-G5, Remmell Fall 2017 USF Tampa, Team S6-G5, Remmell Fall 2017 회원
USFT-REMMELL-F17S6G5
7 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 338
