주요 콘텐츠로 건너뛰기
Acer Chromebook C710-2856 Motherboard Replacement
필요한 것
  1. Acer Chromebook C710-2856 Motherboard Replacement, RAM: 1 단계, 이미지 2개 중 1개 Acer Chromebook C710-2856 Motherboard Replacement, RAM: 1 단계, 이미지 2개 중 2개
    • Remove the one 4.3mm Phillips #1 screw holding the back cover on.
  2. Acer Chromebook C710-2856 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the RAM and the metal clips holding the RAM in place.
  3. Acer Chromebook C710-2856 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook C710-2856 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Push the two clips outwards at the same time with your fingers. The RAM will gently pop upwards.
  4. Acer Chromebook C710-2856 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the RAM out of the slot.
  5. Acer Chromebook C710-2856 Motherboard Replacement, Wi-Fi Card: 5 단계, 이미지 3개 중 1개 Acer Chromebook C710-2856 Motherboard Replacement, Wi-Fi Card: 5 단계, 이미지 3개 중 2개 Acer Chromebook C710-2856 Motherboard Replacement, Wi-Fi Card: 5 단계, 이미지 3개 중 3개
    • Using the Phillips #1 screwdriver, remove the screw from the Wi-Fi card.
    • Carefully remove the piece of tape to allow for more room to remove the Wi-Fi card.
    • Use the blue plastic opening tool to lift and remove the Wi-Fi card from its socket.
  6. Acer Chromebook C710-2856 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Acer Chromebook C710-2856 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Acer Chromebook C710-2856 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Use the blue plastic opening tool and carefully remove the connectors from the Wi-Fi card.
  7. Acer Chromebook C710-2856 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook C710-2856 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the Wi-Fi card.
  8. Acer Chromebook C710-2856 Motherboard Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Unscrew the circled screws, a total of 17 (15 M 2x6 and 2 M 2x3), with a cross-head screwdriver.
  9. Acer Chromebook C710-2856 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Acer Chromebook C710-2856 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Acer Chromebook C710-2856 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Using the blue plastic opening tool, work your way around the perimeter of the laptop and remove the bottom frame.
    • Be careful though, because we will not be pulling it completely apart since we will need to disconnect 2 ribbon cables first (shown in next step).
  10. Acer Chromebook C710-2856 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Acer Chromebook C710-2856 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the green ribbon on the backside of the laptop by pulling on it lightly as shown.
    • Gently remove the back ribbon that is holding the two parts of the laptop together (found between the two parts that are being pulling apart).
  11. Acer Chromebook C710-2856 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Now completely pull apart the motherboard from the underside of the laptop by pulling on the location of the arrows.
  12. Acer Chromebook C710-2856 Motherboard Replacement: 12 단계, 이미지 3개 중 1개 Acer Chromebook C710-2856 Motherboard Replacement: 12 단계, 이미지 3개 중 2개 Acer Chromebook C710-2856 Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Disconnect the five ribbons by pulling gently on the ribbon.
    • Unscrew the M2x3 screw.
    • Disconnect the blue connector from the motherboard.
    • Disconnect the wider white connector from the motherboard.
  13. Acer Chromebook C710-2856 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Acer Chromebook C710-2856 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the motherboard from the frame.
  14. Acer Chromebook C710-2856 Motherboard Replacement: 14 단계, 이미지 3개 중 1개 Acer Chromebook C710-2856 Motherboard Replacement: 14 단계, 이미지 3개 중 2개 Acer Chromebook C710-2856 Motherboard Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the fan by unscrewing two M2x3 screws.
    • Peel the tape off the ribbon connection for easy access.
    • Use the plastic opening tool to disconnect the connector.
  15. Acer Chromebook C710-2856 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 Acer Chromebook C710-2856 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the fan.
  16. Acer Chromebook C710-2856 Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • The motherboard is now bare of any extras and is ready to be replaced.
결론
작성자
1다른 기여자 명과 함께
Vladimir
회원 가입일: 09/27/17
101 평판
안내서 1개를 작성함
USF Tampa, Team S6-G5, Remmell Fall 2017 USF Tampa, Team S6-G5, Remmell Fall 2017 회원
USFT-REMMELL-F17S6G5
7 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 889
