주요 콘텐츠로 건너뛰기
Acer Chromebook C710-2856 Wi-Fi Card Replacement
필요한 것
  1. Acer Chromebook C710-2856 Wi-Fi Card Replacement, Back Cover: 1 단계, 이미지 1/2 Acer Chromebook C710-2856 Wi-Fi Card Replacement, Back Cover: 1 단계, 이미지 2/2
    • Flip the device over and remove the 4.3 mm screw using a Phillips #1 screwdriver.
    • Remove the back cover.
  2. Acer Chromebook C710-2856 Wi-Fi Card Replacement, Wi-Fi Card: 2 단계, 이미지 1/3 Acer Chromebook C710-2856 Wi-Fi Card Replacement, Wi-Fi Card: 2 단계, 이미지 2/3 Acer Chromebook C710-2856 Wi-Fi Card Replacement, Wi-Fi Card: 2 단계, 이미지 3/3
    • Using the Phillips #1 screwdriver, remove the screw from the Wi-Fi card.
    • Carefully remove the piece of tape to allow for more room to remove the Wi-Fi card.
    • Use the blue plastic opening tool to lift and remove the Wi-Fi card from its socket.
  3. Acer Chromebook C710-2856 Wi-Fi Card Replacement: 3 단계, 이미지 1/3 Acer Chromebook C710-2856 Wi-Fi Card Replacement: 3 단계, 이미지 2/3 Acer Chromebook C710-2856 Wi-Fi Card Replacement: 3 단계, 이미지 3/3
    • Use the blue plastic opening tool and carefully remove the connectors from the Wi-Fi card.
  4. Acer Chromebook C710-2856 Wi-Fi Card Replacement: 4 단계, 이미지 1/2 Acer Chromebook C710-2856 Wi-Fi Card Replacement: 4 단계, 이미지 2/2
    • Remove the Wi-Fi card.
결론
John
회원 가입일: 09/27/17
101 평판
안내서 1개 작성함
USF Tampa, Team S6-G5, Remmell Fall 2017 USF Tampa, Team S6-G5, Remmell Fall 2017 회원
USFT-REMMELL-F17S6G5
7 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 410
