주요 콘텐츠로 건너뛰기
Acer Chromebook C720 Battery Replacement
필요한 것
  1. Acer Chromebook C720 Battery Replacement, Battery: 1 단계, 이미지 1/3 Acer Chromebook C720 Battery Replacement, Battery: 1 단계, 이미지 2/3 Acer Chromebook C720 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Operating on your device while it is on, or plugged in may result in electrical shock. Make sure the device is not powered before continuing.
    • Remove the thirteen 6mm screws using a Phillips #0 screwdriver.
    • Gently pry the back plate off using the plastic opening tool, leveraging the groove along the device's hinge.
  2. Acer Chromebook C720 Battery Replacement: 2 단계, 이미지 1/2 Acer Chromebook C720 Battery Replacement: 2 단계, 이미지 2/2
    • Remove the two 3mm screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Battery Replacement: 3 단계, 이미지 1/2 Acer Chromebook C720 Battery Replacement: 3 단계, 이미지 2/2
    • Disconnect the 8-pin ribbon cable from the motherboard.
    • Remove the battery pack from the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Benjamin Rahman
회원 가입일: 04/01/19
517 평판
안내서 3개 작성하였습니다
IUPUI, Team S2-G5, Harley Spring 2019 IUPUI, Team S2-G5, Harley Spring 2019 회원
IUPUI-HARLEY-S19S2G5
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 1,056
