이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Follow these simple steps to remove and replace a battery pack on an Acer Chromebook C720 with, a Philips #0 Screwdriver and plastic opening tool. Before beginning, be sure the device is completely drained, as it is dangerous to work on the device internals while the device is running. Also, remember to handle the device internals with care, as they are fragile and can be broken.
필요한 것
Remove the thirteen 6mm screws using a Phillips #0 screwdriver.
Gently pry the back plate off using the plastic opening tool, leveraging the groove along the device's hinge.
다른 4명이 해당 안내서를 완성하였습니다.
