주요 콘텐츠로 건너뛰기
Acer Chromebook C720 Heat Sink and Cooling Fan Replacement
필요한 것
  1. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: 1 단계, 이미지 3개 중 1개 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: 1 단계, 이미지 3개 중 2개 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: 1 단계, 이미지 3개 중 3개
    • Operating on your device while it is on, or plugged in may result in electrical shock. Make sure the device is not powered before continuing.
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Gently pry the back plate off using the plastic opening tool, leveraging the groove along the device's hinge.
  2. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four 3mm screws securing the heat sink using the Phillips #0 screwdriver.
    • Remove the two 3mm screws securing the fan using the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Gently pry the fan module away from the motherboard. After a bit of force, it should pop out of its slot.
    • Carefully unwrap the wires from around the fan.
  4. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 4 단계, 이미지 3개 중 1개 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 4 단계, 이미지 3개 중 2개 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Gently disconnect the fan module from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Benjamin Rahman
회원 가입일: 04/01/19
529 평판
안내서 3개를 작성함
IUPUI, Team S2-G5, Harley Spring 2019 IUPUI, Team S2-G5, Harley Spring 2019 회원
IUPUI-HARLEY-S19S2G5
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 677
