주요 콘텐츠로 건너뛰기
Acer Chromebook C720 Solid State Drive (SSD) Replacement
필요한 것
  1. Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): 1 단계, 이미지 1/3 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): 1 단계, 이미지 2/3 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): 1 단계, 이미지 3/3
    • WARNING: Make sure your device is turned off before proceeding. If you proceed with the device on, the device may be damaged
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Using the blue plastic case opener, unlatch the back of the case to expose the motherboard and other components.
  2. Acer Chromebook C720 Solid State Drive (SSD) Replacement: 2 단계, 이미지 1/3 Acer Chromebook C720 Solid State Drive (SSD) Replacement: 2 단계, 이미지 2/3 Acer Chromebook C720 Solid State Drive (SSD) Replacement: 2 단계, 이미지 3/3
    • Remove the single 3mm screw holding the SSD with the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Solid State Drive (SSD) Replacement: 3 단계, 이미지 1/2 Acer Chromebook C720 Solid State Drive (SSD) Replacement: 3 단계, 이미지 2/2
    • Gently remove the SSD from the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Benjamin Rahman
회원 가입일: 04/01/19
517 평판
안내서 3개 작성하였습니다
IUPUI, Team S2-G5, Harley Spring 2019 IUPUI, Team S2-G5, Harley Spring 2019 회원
IUPUI-HARLEY-S19S2G5
4 회원들
안내서 7개 작성하였습니다
댓글 2개
When you’re looking for a replacement drive, its socket is for a B-keyed m.2 2242 (22m x 42m). I haven’t actually found any just-B-keyed on the market, so you’ll probably end up getting B+M keyed (like the stock drive).
Another guide which goes further into recovering the OS to the new drive is here: https://www.androidcentral.com/how-upgra...
Matt Beary - 답글
Mi duda es como instalo Chrome os a la ssd nueva
José De Jesús Lopez Guillen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 35
30일 전: 146
전체 시간: 5,463
