주요 콘텐츠로 건너뛰기
Acer Chromebook C720-2103 Battery Replacement
필요한 것
  1. Acer Chromebook C720-2103 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Chromebook C720-2103 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Battery Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook C720-2103 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Battery Replacement: 5 단계, 이미지 2개 중 1개 Acer Chromebook C720-2103 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Matthew Holt
회원 가입일: 10/17/17
633 평판
안내서 5개를 작성함
UMass Dartmouth, Team S66-G3, Rockett Fall 2017 UMass Dartmouth, Team S66-G3, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S66G3
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 9
전체 시간: 846
