주요 콘텐츠로 건너뛰기
Acer Chromebook C720-2103 Solid State Drive Replacement
필요한 것
  1. Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Solid State Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Solid State Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Solid State Drive Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook C720-2103 Solid State Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Solid State Drive Replacement: 5 단계, 이미지 2개 중 1개 Acer Chromebook C720-2103 Solid State Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
  6. Acer Chromebook C720-2103 Solid State Drive Replacement, Solid State Drive: 6 단계, 이미지 1개 중 1개
    • Remove one 6mm screw using a Phillips #0 screwdriver.
  7. Acer Chromebook C720-2103 Solid State Drive Replacement: 7 단계, 이미지 3개 중 1개 Acer Chromebook C720-2103 Solid State Drive Replacement: 7 단계, 이미지 3개 중 2개 Acer Chromebook C720-2103 Solid State Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully remove the solid state drive from the solid state drive slot by sliding it downward away from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Matthew Holt
회원 가입일: 10/17/17
633 평판
안내서 5개를 작성함
UMass Dartmouth, Team S66-G3, Rockett Fall 2017 UMass Dartmouth, Team S66-G3, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S66G3
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 322
